after 1 day of use the program start suddenly to use 100% of my 16 core cpu and display a error windows saying “child process exited with code 1”
Device
Android 12
Samsung Galaxy a52
Windows 11 overkill desktop pc
AudioRelay 0.25.5
If this keeps happening, could you please post the logs from the desktop app?
You can get them from the settings tab or by going to thisfolder: %LOCALAPPDATA%\AudioRelay\Logs\
look this =
2022-09-19 13:36:33:001 [INFO] Initializing locale to es
2022-09-19 13:36:33:028 [INFO] Starting IpcCoordinatorService ...
2022-09-19 13:36:33:076 [INFO] Got open ports at 59300 and 59350
2022-09-19 13:36:33:085 [INFO] Starting the server...
2022-09-19 13:36:33:088 [INFO] Messages socket waiting on a connection...
2022-09-19 13:36:33:088 [INFO] Waiting for devices from windows' backend...
2022-09-19 13:36:33:089 [INFO] Starting backend...
2022-09-19 13:36:33:090 [INFO] Audio socket waiting on a connection...
2022-09-19 13:36:33:099 [INFO] Waiting for devices from PortAudio...
2022-09-19 13:36:33:108 [INFO] Checking for update...
2022-09-19 13:36:33:130 [INFO] Status initializing
2022-09-19 13:36:33:131 [INFO] Portaudio version: PortAudio V19.7.0-devel, revision unknown
2022-09-19 13:36:33:599 [INFO] Wait for backend backend...
2022-09-19 13:36:33:604 [INFO] Status initialized
2022-09-19 13:36:33:826 [INFO] Found no update
2022-09-19 13:36:34:276 [INFO] Audio socket connected
2022-09-19 13:36:34:276 [INFO] Messages socket created
2022-09-19 13:36:34:281 [INFO] Showing main window...
2022-09-19 13:36:34:338 [INFO] Rendering api: DIRECT3D
2022-09-19 13:36:34:645 [INFO] Backend is ready
2022-09-19 13:36:34:650 [INFO] Requesting startup settings...
2022-09-19 13:37:20:256 [INFO] Version: 0.26.3, os: Windows 10, osVersion: 10.0
2022-09-19 13:37:20:688 [INFO] Initializing locale to es
2022-09-19 13:37:20:713 [INFO] Starting IpcCoordinatorService ...
2022-09-19 13:37:20:760 [INFO] Got open ports at 59300 and 59350
2022-09-19 13:37:20:762 [INFO] Starting the server...
2022-09-19 13:37:20:772 [INFO] Waiting for devices from windows' backend...
2022-09-19 13:37:20:784 [INFO] Waiting for devices from PortAudio...
2022-09-19 13:37:20:778 [INFO] Starting backend...
2022-09-19 13:37:20:777 [INFO] Audio socket waiting on a connection...
2022-09-19 13:37:20:776 [INFO] Messages socket waiting on a connection...
2022-09-19 13:37:20:797 [INFO] Checking for update...
2022-09-19 13:37:20:806 [INFO] Status initializing
2022-09-19 13:37:20:807 [INFO] Portaudio version: PortAudio V19.7.0-devel, revision unknown
2022-09-19 13:37:21:098 [INFO] Status initialized
2022-09-19 13:37:21:205 [INFO] Showing main window...
2022-09-19 13:37:21:276 [INFO] Wait for backend backend...
2022-09-19 13:37:21:427 [INFO] Rendering api: DIRECT3D
2022-09-19 13:37:21:514 [INFO] Messages socket created
2022-09-19 13:37:21:518 [INFO] Audio socket connected
2022-09-19 13:37:21:556 [INFO] Found no update
2022-09-19 13:37:21:840 [INFO] Backend is ready
2022-09-19 13:37:21:845 [INFO] Requesting startup settings...
2022-09-19 13:37:34:671 [INFO] Version: 0.26.3, os: Windows 10, osVersion: 10.0
2022-09-19 13:37:35:094 [INFO] Initializing locale to es
2022-09-19 13:37:35:119 [INFO] Starting IpcCoordinatorService ...
2022-09-19 13:37:35:162 [INFO] Got open ports at 59300 and 59350
2022-09-19 13:37:35:165 [INFO] Starting the server...
2022-09-19 13:37:35:173 [INFO] Waiting for devices from windows' backend...
2022-09-19 13:37:35:176 [INFO] Audio socket waiting on a connection...
2022-09-19 13:37:35:176 [INFO] Starting backend...
2022-09-19 13:37:35:178 [INFO] Messages socket waiting on a connection...
2022-09-19 13:37:35:185 [INFO] Waiting for devices from PortAudio...
2022-09-19 13:37:35:193 [INFO] Checking for update...
2022-09-19 13:37:35:216 [INFO] Status initializing
2022-09-19 13:37:35:217 [INFO] Portaudio version: PortAudio V19.7.0-devel, revision unknown
2022-09-19 13:37:35:514 [INFO] Status initialized
2022-09-19 13:37:35:678 [INFO] Wait for backend backend...
2022-09-19 13:37:35:780 [INFO] Found no update
2022-09-19 13:37:35:849 [INFO] Showing main window...
2022-09-19 13:37:35:913 [INFO] Rendering api: DIRECT3D
2022-09-19 13:37:35:924 [INFO] Audio socket connected
2022-09-19 13:37:35:925 [INFO] Messages socket created
2022-09-19 13:37:36:220 [INFO] Backend is ready
2022-09-19 13:37:36:225 [INFO] Requesting startup settings...
2022-09-19 13:38:36:288 [INFO] Version: 0.26.3, os: Windows 10, osVersion: 10.0
2022-09-19 13:38:36:867 [INFO] Initializing locale to es
2022-09-19 13:38:36:901 [INFO] Starting IpcCoordinatorService ...
2022-09-19 13:38:36:966 [INFO] Got open ports at 59300 and 59350
2022-09-19 13:38:36:972 [INFO] Starting the server...
2022-09-19 13:38:36:975 [INFO] Waiting for devices from windows' backend...
2022-09-19 13:38:36:978 [INFO] Messages socket waiting on a connection...
2022-09-19 13:38:36:978 [INFO] Audio socket waiting on a connection...
2022-09-19 13:38:36:979 [INFO] Starting backend...
2022-09-19 13:38:36:989 [INFO] Waiting for devices from PortAudio...
2022-09-19 13:38:36:999 [INFO] Checking for update...
2022-09-19 13:38:37:016 [INFO] Status initializing
2022-09-19 13:38:37:017 [INFO] Portaudio version: PortAudio V19.7.0-devel, revision unknown
2022-09-19 13:38:37:285 [INFO] Status initialized
2022-09-19 13:38:37:483 [INFO] Wait for backend backend...
2022-09-19 13:38:37:577 [INFO] Showing main window...
2022-09-19 13:38:37:669 [INFO] Found no update
2022-09-19 13:38:37:935 [INFO] Rendering api: DIRECT3D
2022-09-19 13:38:38:144 [INFO] Messages socket created
2022-09-19 13:38:38:144 [INFO] Audio socket connected
Unfortunately, the error isn’t in the logs.
Could you please do this?
It’ll run AudioRelay “manually” instead of using AudioRelay.exe.
cd "c:\Program Files (x86)\AudioRelay"
.\runtime\bin\java.exe -cp "app/audiorelay.jar" com.azefsw.audioconnect.desktop.app.MainKt > %USERPROFILE%/desktop/output.log 2>&1
It’ll create a output.log file on your Desktop which should show the underlying issue.
Please post it here.
