When I start the app I get that error message.
I just downloaded the latest version.
I have tried running the app “manually” but I get the same result.
I’m pretty sure my graphics card driver is up to date.
My win ver on the pc:
Microsoft Windows [Version 10.0.19045.2486]
and this is my output log:
2023-02-03 01:39:47:118 [INFO] Version: 0.26.3, os: Windows 10, osVersion: 10.0
2023-02-03 01:39:47:471 [INFO] Initializing locale to en
2023-02-03 01:39:47:492 [INFO] Starting IpcCoordinatorService ...
2023-02-03 01:39:47:529 [INFO] Got open ports at 59300 and 59350
2023-02-03 01:39:47:536 [INFO] Messages socket waiting on a connection...
2023-02-03 01:39:47:539 [INFO] Audio socket waiting on a connection...
2023-02-03 01:39:47:539 [INFO] Waiting for devices from windows' backend...
2023-02-03 01:39:47:541 [INFO] Starting backend...
2023-02-03 01:39:47:542 [INFO] Starting the server...
2023-02-03 01:39:47:547 [INFO] Waiting for devices from PortAudio...
2023-02-03 01:39:47:551 [INFO] Checking for update...
2023-02-03 01:39:47:570 [INFO] Status initializing
2023-02-03 01:39:47:571 [INFO] Portaudio version: PortAudio V19.7.0-devel, revision unknown
2023-02-03 01:39:47:717 [INFO] Status initialized
2023-02-03 01:39:47:951 [INFO] Found no update
2023-02-03 01:39:47:999 [INFO] Showing main window...
2023-02-03 01:39:48:044 [INFO] Wait for backend backend...
2023-02-03 01:39:48:104 [INFO] Messages socket created
2023-02-03 01:39:48:109 [INFO] Audio socket connected
2023-02-03 01:39:48:192 [INFO] Rendering api: DIRECT3D
2023-02-03 01:39:48.571 [INF] Connection ready
2023-02-03 01:39:48.602 [INF] Changing process audiorelay-backend priority from Normal to Normal
2023-02-03 01:39:48.606 [INF] Changing process java priority from Normal to Normal
2023-02-03 01:39:48.619 [INF] Handling windows startup request...
2023-02-03 01:39:48:588 [INFO] Backend is ready
2023-02-03 01:39:48:592 [INFO] Requesting startup settings...
2023-02-03 01:39:48:947 [INFO] Windows' backend devices: [WindowsAudioDevice(id={0.0.0.00000000}.{b33b54fe-4c38-4c9b-a252-d58ee46ae940}, type=Render, name=Digital Audio (S/PDIF) (High Definition Audio Device), isDefault=false, sampleRate=48000, channels=2), WindowsAudioDevice(id={0.0.1.00000000}.{81dd2ef4-c922-4788-afcb-be30c503c2a9}, type=Capture, name=Digital Audio (S/PDIF) (High Definition Audio Device), isDefault=false, sampleRate=44100, channels=2), WindowsAudioDevice(id={0.0.0.00000000}.{054f692d-aa02-41dc-a8ee-069c73f36589}, type=Render, name=Headset Earphone (HyperX Virtual Surround Sound), isDefault=false, sampleRate=48000, channels=2), WindowsAudioDevice(id={0.0.1.00000000}.{7395f051-9746-4e50-9296-ed914b9b0c91}, type=Capture, name=Headset Microphone (HyperX Virtual Surround Sound), isDefault=false, sampleRate=48000, channels=2), WindowsAudioDevice(id={0.0.0.00000000}.{1939c59a-575e-4dd6-8c37-93c237a4a599}, type=Render, name=Speakers (High Definition Audio Device), isDefault=false, sampleRate=48000, channels=2), WindowsAudioDevice(id={0.0.1.00000000}.{448c8d8e-b5a7-4357-87d6-29186d68bd22}, type=Capture, name=Virtual Mic (Virtual Mic for AudioRelay), isDefault=false, sampleRate=48000, channels=2), WindowsAudioDevice(id={0.0.0.00000000}.{faa52ac6-799b-465a-a9c5-1854b5ef2c09}, type=Render, name=Virtual Speakers (Virtual Speakers for AudioRelay), isDefault=true, sampleRate=48000, channels=2)]
Failed Direct3D call. Error: 0x887a0005
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x00007ff93af93261, pid=13216, tid=2848
# JRE version: OpenJDK Runtime Environment Temurin-17.0.2+8 (17.0.2+8) (build 17.0.2+8)
# Java VM: OpenJDK 64-Bit Server VM Temurin-17.0.2+8 (17.0.2+8, mixed mode, tiered, compressed class ptrs, z gc, windows-amd64)
# Problematic frame:
# V [jvm.dll+0x3e3261]
# No core dump will be written. Minidumps are not enabled by default on client versions of Windows
# An error report file with more information is saved as:
# F:\AudioRelay\hs_err_pid13216.log
# If you would like to submit a bug report, please visit:
# https://github.com/adoptium/adoptium-support/issues
2023-02-03 01:39:50.362 [ERR] Socket service error
System.IO.IOException: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host. ---> System.Net.Sockets.SocketException: An existing connection was forcibly closed by the remote host
at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags)
at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size)
--- End of inner exception stack trace ---
at System.IO.Stream.ReadByte()
at Google.Protobuf.ParsingPrimitives.ReadRawVarint32(Stream input)
at Google.Protobuf.MessageExtensions.MergeDelimitedFrom(IMessage message, Stream input, Boolean discardUnknownFields, ExtensionRegistry registry)
at Google.Protobuf.MessageParser`1.ParseDelimitedFrom(Stream input)
at AudioConnect.Ipc.IpcSocketsService.<>c__DisplayClass10_0.<ReadMessages>b__0()
at AudioConnect.Rx.Observables.<>c__DisplayClass2_1`1.<InfiniteLongRunningImpl>b__1(Int32 _, ICancelable cancelable)
2023-02-03 01:39:50.366 [INF] Connection lost
2023-02-03 01:39:54.437 [ERR] Sockets failed
System.Net.Sockets.SocketException (0x80004005): No connection could be made because the target machine actively refused it 127.0.0.1:59300
at System.Net.Sockets.TcpClient..ctor(String hostname, Int32 port)
at AudioConnect.Ipc.IpcSocketsService.CreateSocket(Int32 configMessagePort)
at AudioConnect.Ipc.IpcSocketsService.<>c__DisplayClass8_0.<StartMessages>b__0()
at System.Reactive.Linq.ObservableImpl.Using`2._.Run(Using`2 parent)
