Can't connect when enabling MAC filtering
I was using the app just fine, but after setting up a MAC filter on my modem, neither the PC or Smartphone can see each other. Disabling the MAC filter make then work normally, só I am 100% sure the issue is the MAC filter.
Computer to Smartphone.
Android 14
Xiaomi POCO X5 5G
BRX, Windows 11
Edit; both can access the internet it the MAC filter enabled, the issue is not Random Mac or misconfiguration.
It seems like your modem isolates the devices when enabling MAC filtering. I’d try to look out for settings such as “Client Isolation” / “WLAN Partition” / “Guest network” etc.
