Can't connect, blocked of sorts
Yes I’ve checked if it’s the firewall, I’ve disabled windows firewall along with Avast’s firewall to no avail, I don’t think my phone has a firewall so it mustn’t have been that.
Windows 10
AudioRelay 1.0
realme 10 Pro 5G
AudioRelay 1.0
  • Does the app sees the server or do you have to manually enter the IP address?
  • Is it possible to ping your devices?
    • (There’s termux for Android)
Could you try the latest version available here:
There have been some changes to the network ports that AudioRelay use by default which could help.
