Bug apt install ends in "xdg-desktop-menu: No writable system menu directory found."
Apt install crashes on my headless debian install
PRETTY_NAME=“Debian GNU/Linux 11 (bullseye)”
NAME=“Debian GNU/Linux”
VERSION_ID=“11”
VERSION=“11 (bullseye)”
VERSION_CODENAME=bullseye
ID=debian
Also I think this debian version does not have a audio subsystem pre-installed which also might cause problems ;-)
Here the console Outputs after apt install
cat Apt Do Install
Raw = False: [b’(Reading database … \r’]
Raw = False: [b’(Reading database … 5%\r(Reading database … 10%\r(Reading database … 15%\r(Reading database … 20%\r(Reading database … 25%\r(Reading database … 30%\r(Reading dat>
Raw = False: [b’(Reading database … 60%\r’]
Raw = False: [b’(Reading database … 65%\r’]
Raw = False: [b’(Reading database … 70%\r’]
Raw = False: [b’(Reading database … 75%\r’]
Raw = False: [b’(Reading database … 80%\r’]
Raw = False: [b’(Reading database … 85%\r’]
Raw = False: [b’(Reading database … 90%\r’]
Raw = False: [b’(Reading database … 95%\r’]
Raw = False: [b’(Reading database … 100%\r(Reading database … 100961 files and directories currently installed.)\r\n’]
Raw = False: [b’Removing audiorelay (0.27.5-1) …\r\n’]
Raw = False: [b’xdg-desktop-menu: No writable system menu directory found.\r\n’]
Raw = False: [b’dpkg: error processing package audiorelay (–remove):\r\n installed audiorelay package pre-removal script subprocess returned error exit status 3\r\ndpkg: too many errors, s>
Data_Split = [b’dpkg: error processing package audiorelay (–remove):‘, b’ installed audiorelay package pre-removal script subprocess returned error exit status 3’, b’dpkg: too many errors,> Raw = False: [b’Errors were encountered while processing:\r\n audiorelay\r\nProcessing was halted because there were too many errors.\r\n’]
Data_Split = [b’Errors were encountered while processing:‘, b’ audiorelay’, b’Processing was halted because there were too many errors.']
[‘Traceback (most recent call last):\n’, ’ File “/usr/lib/python3/dist-packages/nala/dpkg.py”, line 461, in run_install\n os._exit(apt.do_install(self.write_stream.fileno())) # type: i>
cat /var/log/nala/dpkg-debug.log
  1. List item
Apt Do Install
