Thanks for the details, I couldn’t reproduce the issue but it should no longer be a problem with the new desktop version (0.24.7). You can force an update check through the app’s settings.
That seams to resolve the problem.
Now I try to find why I get Latency spikes and the sound gets a small crackling even if the WiFi is at least 1 meter from the phone and the PC is conected to it.
