On macOS window close should just hide the window instead of quiting program. This is how it’s usually done in macOS. Now if you press close button AudioRelay shutting down and exit. So only way to hide the window is to use minimise button but that’s made for a different purpose. So please implement a proper way to hide a window.
+1 I wonder how we can have such feature being prioritized. It feels silly enough that this works on Windows but not MacOS ….
Made an account just to reply to you in agreement.
You can’t do it on Linux either,
other than not being able to close the window its a perfect app it seems.
The current implementation on macOS in the latest early access versions (Announcements - AudioRelay) is:
- Add a menubar icon
Cmd+Qto quit the whole appCmd+Wto close the window, remove the app from the dock and the app stays available from the menubar
