Automatic transition between USB & WiFi
Hi, I have a feature request, and felt the best way to describe it would be with simple scenario:
  • As I am working around the house, AudioRelay is transmitting audio to my phone via WiFi
    • I sit down at my PC and know that I have atleast an hour of free time, so I connect my phone via USB
      • AudioRelay detects the USB connection and automatically switches to the USB tethered IP Address.
    • Break time is over, so I disconnect my phone from USB and put it back in my pocket
      • AudioRelay detects this and automatically switches back to the WiFi IP.
There is my suggestion :slight_smile:. Thank you and great work!
Great Idea! I would also like to see this feature implemented if possible.
