Automate connecting to server with same name
can they add “NPU” support to automate connecting to certian server (differant adress if server has same name)?
need this
this will be very helpful if some how it disconnect
@here Version 1.0.0 will introduce unique device IDs for each machine. It should help to connect to the correct server, even if it changes its IP address.
If you’re looking to connect to the same physical device, with the same device ID, then your request should be implemented at the same as Auto reconnect to last server used.
Or do you want to connect to potentially different physical devices that have been setup with the same name? (They’d have different device IDs)
What’s the use case then?
What’s NPU? I’ve found the suggestion “Network Policy Unit”
