here are the logs:
2023-11-16 19:47:19:923 [INFO] Requesting startup settings…
2023-11-16 19:47:20:092 [INFO] Windows’ backend devices: [WindowsAudioDevice(id={0.0.0.00000000}.{5ff91cb0-e89c-4a6f-922d-415222879ab7}, type=Render, name=Digital Audio (S/PDIF) (2- High Definition Audio Device), isDefault=false, sampleRate=48000, channels=2), WindowsAudioDevice(id={0.0.1.00000000}.{9a8489ea-89b2-409f-b76b-72a19d8bf9d5}, type=Capture, name=Microphone (Steam Streaming Microphone), isDefault=false, sampleRate=44100, channels=1), WindowsAudioDevice(id={0.0.0.00000000}.{86254844-b182-4260-bbc5-d0ef17eea27c}, type=Render, name=Speakers (Steam Streaming Microphone), isDefault=false, sampleRate=48000, channels=2), WindowsAudioDevice(id={0.0.0.00000000}.{a17192f3-2f1b-4d98-b42f-dfb22e6022b4}, type=Render, name=Speakers (Steam Streaming Speakers), isDefault=false, sampleRate=48000, channels=2), WindowsAudioDevice(id={0.0.1.00000000}.{b111d19a-7c9c-4d1f-8840-a0f9734d8f27}, type=Capture, name=Virtual Mic (Virtual Mic for AudioRelay), isDefault=false, sampleRate=48000, channels=2), WindowsAudioDevice(id={0.0.0.00000000}.{2a4f19d9-0eb3-4a94-a4ca-601dee8af69f}, type=Render, name=Virtual Speakers (Virtual Speakers for AudioRelay), isDefault=true, sampleRate=48000, channels=2), WindowsAudioDevice(id={0.0.0.00000000}.{782dd577-852a-4cac-9d0d-750ab5cf557b}, type=Render, name=VZ229 (NVIDIA High Definition Audio), isDefault=false, sampleRate=48000, channels=2)]
2023-11-16 19:47:20:575 [INFO] Showing main window…
2023-11-16 19:47:21:674 [INFO] Rendering api: DIRECT3D
2023-11-16 19:47:22:124 [INFO] Virtual mic: 1.0.2.0, Virtual speaker: 1.0.2.0
2023-11-16 19:47:22:141 [INFO] Network addresses: NetworkInfo(broadcastAddresses=[192.168.1.255], localAddresses=[192.168.1.25])
2023-11-16 19:47:24:181 [INFO] Destroying backend due to cancellation…
2023-11-16 19:47:24:183 [INFO] Stopping the server, reason: shutdown
2023-11-16 19:48:31:413 [INFO] Version: 0.27.5, os: Windows 10, osVersion: 10.0
2023-11-16 19:48:31:888 [INFO] Initializing locale to en
2023-11-16 19:48:31:927 [INFO] Starting IpcCoordinatorService …
2023-11-16 19:48:31:967 [INFO] Got open ports at 59300 and 59350
2023-11-16 19:48:31:972 [INFO] Starting the server…
2023-11-16 19:48:31:972 [INFO] Messages socket waiting on a connection…
2023-11-16 19:48:31:973 [INFO] Audio socket waiting on a connection…
2023-11-16 19:48:31:973 [INFO] Waiting for devices from windows’ backend…
2023-11-16 19:48:31:973 [INFO] Starting backend…
2023-11-16 19:48:31:978 [INFO] Waiting for devices from RtAudio…
2023-11-16 19:48:32:049 [INFO] Checking for update…
2023-11-16 19:48:32:476 [INFO] Wait for backend backend…
2023-11-16 19:48:32:679 [INFO] Found no update
2023-11-16 19:48:33:045 [INFO] Messages socket created
2023-11-16 19:48:33:045 [INFO] Audio socket connected
2023-11-16 19:48:33:522 [INFO] Backend is ready
2023-11-16 19:48:33:528 [INFO] Requesting startup settings…
2023-11-16 19:48:33:765 [INFO] Windows’ backend devices: [WindowsAudioDevice(id={0.0.0.00000000}.{5ff91cb0-e89c-4a6f-922d-415222879ab7}, type=Render, name=Digital Audio (S/PDIF) (2- High Definition Audio Device), isDefault=false, sampleRate=48000, channels=2), WindowsAudioDevice(id={0.0.1.00000000}.{9a8489ea-89b2-409f-b76b-72a19d8bf9d5}, type=Capture, name=Microphone (Steam Streaming Microphone), isDefault=false, sampleRate=44100, channels=1), WindowsAudioDevice(id={0.0.0.00000000}.{86254844-b182-4260-bbc5-d0ef17eea27c}, type=Render, name=Speakers (Steam Streaming Microphone), isDefault=false, sampleRate=48000, channels=2), WindowsAudioDevice(id={0.0.0.00000000}.{a17192f3-2f1b-4d98-b42f-dfb22e6022b4}, type=Render, name=Speakers (Steam Streaming Speakers), isDefault=false, sampleRate=48000, channels=2), WindowsAudioDevice(id={0.0.1.00000000}.{b111d19a-7c9c-4d1f-8840-a0f9734d8f27}, type=Capture, name=Virtual Mic (Virtual Mic for AudioRelay), isDefault=false, sampleRate=48000, channels=2), WindowsAudioDevice(id={0.0.0.00000000}.{2a4f19d9-0eb3-4a94-a4ca-601dee8af69f}, type=Render, name=Virtual Speakers (Virtual Speakers for AudioRelay), isDefault=true, sampleRate=48000, channels=2), WindowsAudioDevice(id={0.0.0.00000000}.{782dd577-852a-4cac-9d0d-750ab5cf557b}, type=Render, name=VZ229 (NVIDIA High Definition Audio), isDefault=false, sampleRate=48000, channels=2)]
2023-11-16 19:48:34:099 [INFO] Showing main window…
2023-11-16 19:48:35:307 [INFO] Rendering api: DIRECT3D
2023-11-16 19:48:35:939 [INFO] Network addresses: NetworkInfo(broadcastAddresses=[192.168.1.255], localAddresses=[192.168.1.25])
2023-11-16 19:48:38:426 [INFO] Virtual mic: 1.0.2.0, Virtual speaker: 1.0.2.0
2023-11-16 19:48:47:493 [INFO] Remote device connected: 192.168.1.24
2023-11-16 19:48:47:546 [INFO] Received client config, clientVersion: 0.26.1, os: ANDROID, osVersion: Android API 30
2023-11-16 19:48:47:559 [INFO] Asking backend to start capture. EventSync: true, ContinuousStream: true, AudioConfig: AudioConfig(sampleRate=48000, bits=16, channels=2), AudioDevice: Virtual Speakers (Virtual Speakers for AudioRelay),
2023-11-16 19:48:48:090 [INFO] Audio pipeline is emitting values
2023-11-16 19:58:14:873 [INFO] Remote device disconnected: 192.168.1.24…
2023-11-16 19:58:14:877 [INFO] Asking backend to stop capture…
2023-11-16 19:58:16:757 [INFO] Remote device connected: 192.168.1.24
2023-11-16 19:58:16:767 [INFO] Received client config, clientVersion: 0.26.1, os: ANDROID, osVersion: Android API 30
2023-11-16 19:58:16:768 [INFO] Asking backend to start capture. EventSync: true, ContinuousStream: true, AudioConfig: AudioConfig(sampleRate=48000, bits=16, channels=2), AudioDevice: Virtual Speakers (Virtual Speakers for AudioRelay),
2023-11-16 19:58:17:280 [INFO] Audio pipeline is emitting values
backend logs
2023-11-16 19:32:04.350 [INF] Changing process AudioRelay priority from Normal to High
2023-11-16 19:32:04.354 [INF] Starting a capture…
2023-11-16 19:32:04.466 [INF] Capture using the suggested format 16 bit PCM: 48kHz 2 channels
2023-11-16 19:32:27.007 [INF] Stopping the capture…
2023-11-16 19:32:27.139 [INF] Starting a capture…
2023-11-16 19:32:27.165 [INF] Capture using the suggested format 16 bit PCM: 48kHz 2 channels
2023-11-16 19:32:28.499 [INF] Detected audio devices changes
2023-11-16 19:32:31.702 [INF] Stopping the capture…
2023-11-16 19:32:31.832 [INF] Starting a capture…
2023-11-16 19:32:31.841 [INF] Capture using the suggested format 16 bit PCM: 48kHz 2 channels
2023-11-16 19:36:00.428 [INF] Connection ready
2023-11-16 19:36:00.464 [INF] Changing process audiorelay-backend priority from Normal to Normal
2023-11-16 19:36:00.464 [INF] Handling windows startup request…
2023-11-16 19:36:00.472 [INF] Changing process AudioRelay priority from Normal to Normal
2023-11-16 19:36:02.958 [INF] Detected audio devices changes
2023-11-16 19:36:03.888 [INF] Detected audio devices changes
2023-11-16 19:36:04.548 [INF] Detected audio devices changes
2023-11-16 19:36:05.153 [INF] Detected audio devices changes
2023-11-16 19:36:05.528 [INF] Detected audio devices changes
2023-11-16 19:36:05.979 [INF] Detected audio devices changes
2023-11-16 19:36:07.437 [INF] Detected audio devices changes
2023-11-16 19:36:08.473 [INF] Changing process audiorelay-backend priority from Normal to High
2023-11-16 19:36:08.477 [INF] Changing process AudioRelay priority from Normal to High
2023-11-16 19:36:08.482 [INF] Starting a capture…
2023-11-16 19:36:08.671 [INF] Capture using the suggested format 16 bit PCM: 48kHz 2 channels
2023-11-16 19:37:28.189 [INF] Detected audio devices changes
2023-11-16 19:37:42.359 [INF] Stopping the capture…
2023-11-16 19:37:42.359 [INF] Changing process audiorelay-backend priority from High to Normal
2023-11-16 19:37:42.362 [INF] Changing process AudioRelay priority from High to Normal
2023-11-16 19:38:17.032 [INF] Starting a capture…
2023-11-16 19:38:17.035 [INF] Changing process audiorelay-backend priority from Normal to High
2023-11-16 19:38:17.039 [INF] Changing process AudioRelay priority from Normal to High
2023-11-16 19:38:17.049 [INF] Capture using the suggested format 16 bit PCM: 48kHz 2 channels
2023-11-16 19:48:33.503 [INF] Connection ready
2023-11-16 19:48:33.534 [INF] Handling windows startup request…
2023-11-16 19:48:33.534 [INF] Changing process audiorelay-backend priority from Normal to Normal
2023-11-16 19:48:33.540 [INF] Changing process AudioRelay priority from Normal to Normal
2023-11-16 19:48:41.453 [INF] Detected audio devices changes
2023-11-16 19:48:42.154 [INF] Detected audio devices changes
2023-11-16 19:48:42.705 [INF] Detected audio devices changes
2023-11-16 19:48:43.186 [INF] Detected audio devices changes
2023-11-16 19:48:43.544 [INF] Detected audio devices changes
2023-11-16 19:48:43.871 [INF] Detected audio devices changes
2023-11-16 19:48:45.258 [INF] Detected audio devices changes
2023-11-16 19:48:47.554 [INF] Changing process audiorelay-backend priority from Normal to High
2023-11-16 19:48:47.557 [INF] Changing process AudioRelay priority from Normal to High
2023-11-16 19:48:47.561 [INF] Starting a capture…
2023-11-16 19:48:47.713 [INF] Capture using the suggested format 16 bit PCM: 48kHz 2 channels
2023-11-16 19:58:14.878 [INF] Stopping the capture…
2023-11-16 19:58:14.879 [INF] Changing process audiorelay-backend priority from High to Normal
2023-11-16 19:58:14.883 [INF] Changing process AudioRelay priority from High to Normal
2023-11-16 19:58:16.768 [INF] Starting a capture…
2023-11-16 19:58:16.770 [INF] Changing process audiorelay-backend priority from Normal to High
2023-11-16 19:58:16.774 [INF] Changing process AudioRelay priority from Normal to High
2023-11-16 19:58:16.782 [INF] Capture using the suggested format 16 bit PCM: 48kHz 2 channels
2023-11-16 19:58:35.563 [INF] Detected audio devices changes
