AudioRelay isn't picking up my phone when I try to use it as a mic?
I fixed my previous issue by using a USB cable, my phone can receive audio from my PC now, but now I have a different issue, I can’t use the “use phone as a mic” feature? I’m using USB and when I start hosting mic on my phone, it doesn’t pop up in the servers tab, and if I try to directly connect to it through the IP it just loads for a bit then kicks me out, could someone help? (sending audio to my phone is fine btw)
Android 11
OPPO A5 2020
AudioRelay 26.1 (Playstore Version)
PC:
Asus, Windows 10
AudioRelay 27.5 (Downloaded through AudioRelay.net)
