Asapha
1
In case Windows SmartScreen blocks the installer
- Right-click on the downloaded file
- Click on properties
- Go to the bottom, click on the unblock checkbox
- Re-execute the installer
- Removed an unnecessary audio conversion step if the selected audio device is already in the target format (48kHz 16-bit 2ch)
- Better handling of audio devices configured with more than 2 channels
- Uses way less CPU
- All channels are merged in the output stream
- Added hints in case changing the format could improve the stream
