Audio relay pc server not detected on android but can stream android but not pc itsel
*Describe the problem here.
hey it’s my first time using audio relay and i tried to stream pc audio into android but it’s not working, the server itself not detected on android but when i try to stream android audio into the pc it’s working just fine, and i already tried using manual input of the ip
Lenovo ideapad gaming 3 15ACH6
Android 13
Xiaomi Mi pad 5
AudioRelay 0.2.6.1
Asus, Windows 11
AudioRelay 0.2.75
okay this might sound dumb but i managed to “Fix” it by clicking the x mark on server tab on windows…
like… i don’t know if im dumb or the instruction is unclear like i just stumble on it by accident
