Audio drops volume automatically with loud sounds (v0.27.5)
When I play loud sounds, the volume drops automatically. Is there a way to disable automatic compression or volume normalization in AudioRelay version 0.27.5?
@SlooweH You can play around the Audio output settings in the Android app. Try AudioTrack and toggle the Request low latency option. Same with with the Enable audio effects option of OpenSL ES
