Hi, I downloaded Audio Relay today. My window sound is transferring to my phone. But my DAW Sound which is cubase 14 pro Not working in phone. i heard that sound in Speakers.
i tried changing Drivers and all connection check. Cant able to figure out how this gonna work.
Hi, from this thread made in 2023, it seems that Cubase doesn’t provide a way to output audio using WASAPI in non-exclusive mode. As of right now, this is necessary for AudioRelay to work as it uses loopback recording.
I think that you should be able to send audio using VB-Cable:
Install it
Select Cable Output as the output device in Cubase
In AudioRelay, choose Cable Input (not Cable Output)
