Android will pause playback (but not disconnect) after a while in the background, even if battery optimization is turned off
Description and Steps to reproduce
  1. Open AudioRelay on windows (as server) and android (as player). On android 14, give audiorelay all permissions. Turn on the software’s self-start and turn off battery optimization. Play a video on windows. Both of them work fine at this stage. I can hear the sound.
  2. On windows, pause the video. On android 14, switch to other apps and use them for a while. Wait for about 3 minutes.
  3. On windows, play the video again. You can see that the windows app and android still running and connecting. But no sound is playing by android.
Windows 10
Xiaomi 13 Pro, MIUI 14, Android 14
Logs that may help:
audiorelay.backend.log
2023-11-05 20:37:26.068 [INF] Changing process audiorelay-backend priority from High to Normal
2023-11-05 20:37:26.101 [INF] Changing process AudioRelay priority from High to Normal
2023-11-05 20:37:29.150 [INF] Starting a capture...
2023-11-05 20:37:29.157 [INF] Changing process audiorelay-backend priority from Normal to High
2023-11-05 20:37:29.162 [INF] Capture using the suggested format 16 bit PCM: 48kHz 2 channels
2023-11-05 20:37:29.186 [INF] Changing process AudioRelay priority from Normal to High
2023-11-05 20:38:03.806 [INF] Detected audio devices changes
2023-11-05 20:39:19.323 [INF] Detected audio devices changes
2023-11-05 20:39:28.708 [INF] Detected audio devices changes
2023-11-05 20:52:57.271 [INF] Detected audio devices changes
2023-11-05 20:52:57.281 [INF] Stopping the capture...
2023-11-05 20:52:57.399 [INF] Starting a capture...
2023-11-05 20:52:57.399 [INF] Stopping the capture...
2023-11-05 20:52:57.420 [INF] Capture using the suggested format 16 bit PCM: 48kHz 2 channels
2023-11-05 20:52:59.222 [INF] Detected audio devices changes
2023-11-05 20:52:59.232 [INF] Stopping the capture...
2023-11-05 20:52:59.348 [INF] Starting a capture...
2023-11-05 20:52:59.348 [INF] Stopping the capture...
2023-11-05 20:52:59.367 [INF] Capture using the suggested format 16 bit PCM: 48kHz 2 channels
2023-11-05 20:53:00.695 [INF] Detected audio devices changes
2023-11-05 21:01:02.824 [INF] Detected audio devices changes
2023-11-05 21:01:04.016 [INF] Detected audio devices changes
2023-11-05 21:01:24.001 [INF] Detected audio devices changes
2023-11-05 21:01:26.249 [INF] Detected audio devices changes
2023-11-05 21:12:05.600 [INF] Detected audio devices changes
2023-11-05 21:12:09.983 [INF] Detected audio devices changes
2023-11-05 21:12:13.764 [INF] Detected audio devices changes
2023-11-05 21:12:41.148 [INF] Detected audio devices changes
2023-11-05 21:13:04.871 [INF] Detected audio devices changes
2023-11-05 21:14:56.054 [INF] Detected audio devices changes
audiorelay.log
2023-11-05 20:37:27:434 [INFO] Remote device connected: 192.168.1.194
2023-11-05 20:37:27:437 [ERROR] Initial TCP communication failed: Pb0
	at Ob0.a(SourceFile:2)
	at lT0.a(SourceFile:154)
	at l8.b(SourceFile:4)
	at O7.a(SourceFile:43)
	at Wi0.b(SourceFile:14)
	at nk0.b(SourceFile:3)
	at pj0.run(SourceFile:68)
	at MG0.invoke(SourceFile:1)
	at bT.invokeSuspend(SourceFile:6)
	at bT.invoke(SourceFile:1)
	at ki1.a(SourceFile:136)
	at a0.a(SourceFile:41)
	at OG0.a(SourceFile:139)
	at NG0.invoke(SourceFile:2)
	at Hu.invokeSuspend(SourceFile:12)
	at jUr4.resumeWith(SourceFile:5)
	at Eu.run(SourceFile:163)
	at Q40.run(SourceFile:4)
	at Ba1.run(SourceFile:1)
	at Yj.run(SourceFile:19)
2023-11-05 20:37:27:593 [ERROR] Initial TCP communication failed: Pb0
2023-11-05 20:37:27:618 [INFO] Remote device connected: 192.168.1.194
2023-11-05 20:37:27:799 [INFO] Remote device connected: 192.168.1.194
2023-11-05 20:37:27:954 [INFO] Remote device connected: 192.168.1.194
2023-11-05 20:37:28:127 [INFO] Remote device connected: 192.168.1.194
2023-11-05 20:37:28:435 [ERROR] Initial TCP communication failed: Pb0
2023-11-05 20:37:28:621 [ERROR] Initial TCP communication failed: Pb0
2023-11-05 20:37:28:807 [ERROR] Initial TCP communication failed: Pb0
2023-11-05 20:37:28:960 [ERROR] Initial TCP communication failed: Pb0
2023-11-05 20:37:29:149 [INFO] Received client config, clientVersion: 0.26.1, os: ANDROID, osVersion: Android API 34
2023-11-05 20:37:29:150 [INFO] Asking backend to start capture. EventSync: false, ContinuousStream: true, AudioConfig: AudioConfig(sampleRate=48000, bits=16, channels=2), AudioDevice: Realtek Digital Output (Realtek(R) Audio),
2023-11-05 20:37:29:659 [INFO] Audio pipeline is emitting values
2023-11-05 20:52:57:280 [INFO] Asking backend to stop capture...
2023-11-05 20:52:57:280 [INFO] Windows' backend devices: [WindowsAudioDevice(id={0.0.0.00000000}.{d8993cf6-0597-46c6-8ebe-e10327bcd3c9}, type=Render, name=Realtek Digital Output (Realtek(R) Audio), isDefault=true, sampleRate=48000, channels=2), WindowsAudioDevice(id={0.0.1.00000000}.{b595aa7f-9b12-47c8-affb-5bb45505755c}, type=Capture, name=Virtual Mic (Virtual Mic for AudioRelay), isDefault=false, sampleRate=48000, channels=2), WindowsAudioDevice(id={0.0.0.00000000}.{139cf6d8-2d2a-444a-8714-1fb9c3777d11}, type=Render, name=Virtual Speakers (Virtual Speakers for AudioRelay), isDefault=false, sampleRate=48000, channels=2)]
2023-11-05 20:52:57:281 [INFO] Asking backend to start capture. EventSync: false, ContinuousStream: true, AudioConfig: AudioConfig(sampleRate=48000, bits=16, channels=2), AudioDevice: Realtek Digital Output (Realtek(R) Audio),
2023-11-05 20:52:57:281 [INFO] Asking backend to stop capture...
2023-11-05 20:52:57:282 [INFO] Asking backend to start capture. EventSync: false, ContinuousStream: true, AudioConfig: AudioConfig(sampleRate=48000, bits=16, channels=2), AudioDevice: Realtek Digital Output (Realtek(R) Audio),
2023-11-05 20:52:59:232 [INFO] Windows' backend devices: [WindowsAudioDevice(id={0.0.0.00000000}.{51aa7506-54c9-4e9a-bcc4-f3bada01e053}, type=Render, name=Q2401W1 (NVIDIA High Definition Audio), isDefault=false, sampleRate=48000, channels=2), WindowsAudioDevice(id={0.0.0.00000000}.{d8993cf6-0597-46c6-8ebe-e10327bcd3c9}, type=Render, name=Realtek Digital Output (Realtek(R) Audio), isDefault=true, sampleRate=48000, channels=2), WindowsAudioDevice(id={0.0.0.00000000}.{22f0a270-9d67-4ea1-bb0c-d72799e143c5}, type=Render, name=U28P2G6B (NVIDIA High Definition Audio), isDefault=false, sampleRate=48000, channels=2), WindowsAudioDevice(id={0.0.1.00000000}.{b595aa7f-9b12-47c8-affb-5bb45505755c}, type=Capture, name=Virtual Mic (Virtual Mic for AudioRelay), isDefault=false, sampleRate=48000, channels=2), WindowsAudioDevice(id={0.0.0.00000000}.{139cf6d8-2d2a-444a-8714-1fb9c3777d11}, type=Render, name=Virtual Speakers (Virtual Speakers for AudioRelay), isDefault=false, sampleRate=48000, channels=2)]
2023-11-05 20:52:59:232 [INFO] Asking backend to stop capture...
2023-11-05 20:52:59:233 [INFO] Asking backend to start capture. EventSync: false, ContinuousStream: true, AudioConfig: AudioConfig(sampleRate=48000, bits=16, channels=2), AudioDevice: Realtek Digital Output (Realtek(R) Audio),
2023-11-05 20:52:59:233 [INFO] Asking backend to stop capture...
I can confirm this with both my poco f4 gt and xiaomi pad 6s pro. Both stop playing audio from my pc after some silence on the windows server. Even when streaming from one android phone to another.
Another detail to add is this only happens when the android app is in the background. If the app stays on the foreground, it continues to play even after a long silence on the server.
having this exact same issue on my Xiaomi 13 Pro
i was prv using Samsun Galaxy and had no issue at all but after updating to Adnroid 14, it is not happening well.
what to do
Got it resolved
Reboot the phone
update PC application
check firewall settings and update them
and done
Yes, I’m also experiencing this issue since I upgraded my Redmi phone to Hyper OS (based on Android 14). I’ve temporarily solved the problem before by workarounds like windowing the apps small and hiding them on the side, but lately that also fails more often than not. The app must be opened and reconnected to stream audio.
@Here, it’s been a while! It should (hopefully) no longer be an issue starting with version 1.0.0-alpha08. Available here
Related bug report
Unfortunately, it still cuts out on my Xiaomi after not playing anything on Windows for a few seconds. I tried everything and turning it into a small window is the only thing that works :smiling_face_with_tear:
You said “everything”, does that mean that this suggestion didn’t work for you?
I tried the solution mentioned but still nothing for me, audiorelay still needs to be reopened after a little time of silence i’m on a xiaomi device
