Android Widget
It would be great if there was a widget that you can use to do things like:
Recent connections
Saved / Pinned connections
Enable / Disable toggle
Display active connection (with mini latency graph)
Kind of like just a mini hub of the app where you can do the basics without having to open the app.
A widget would be a great idea especially a start playing widget button. !!! Thank you!!!
