Android to Android: The connection is down or something is blocking it
Hey. Ive been using the app to cast music from a samsung phone to a tablet using WiFi. Most of the time when i first try to connect the tablet to the phone, the tablet doesnt show an active server and when i try to connect by address i get the message *“*The connection is down or something is blocking it”. At some point (usually after 15-20 minutes) the tablet suddenly recognizes an active server and it resolves by itself. I was wondering what could be the reason and how i can connect the devices on the first try, as I need it for work and its quite time sensitive. :slight_smile:
Both devices have allowed all permissions, unrestricted battery usage, and do not use any kind of antivirus app. I tried force stopping, clearing cache and clearing data on both apps to make the connection happen faster but it didnt help.
Thanks for any help in advance!
@VladiP Could you please try the latest version from Announcements? Networking has changed a bit.
