After Upgrading to Android 15, Casting through AudioRelay from Android to PC ends when the screen sleeps/locks.
Android 15
Pixel 7
Asus, Windows 11
Here is a link to the last 1000 lines from my Android Logs
I’m also have the same problem on pixel 6a. Server is forced inactive once the screen turns off. I’ve looked for battery optimization settings and permissions settings for a fix but came up empty handed.
My temporary Solution is to download something like “Keep Screen On” and to keep the phone plugged in while I have it casting.
Not ideal, but a work around, at least.
No need for a download, in System > developer settings the settings called “stay awake” will keep the screen on if it’s plugged in.
I should have been more clear, this just adds a quick settings card so you can toggle it quickly.
