Add option to disable and rename servers from pc
Currently, if you host the app from the pc and have the connection made both with wifi and usb tethering, there’s two separate ip address connections made available and there’s no way to tell which is which. This gets annoying when trying to reconnect after a connection is lost.
Having a ‘disable’ feature, and some user-friendly (maybe even editable) subtitles like “wifi” and “tethering” would go a long way to improve app usability.
P.S I’m a programmer, and i’m willing to sign an NDA and implement some features myself for free, since I really just wanna improve my user experience, and it’s not worth it to start a similar app from scratch
