Hi, I’m wondering if 24-Bit will be available in the near future for this App. As using for example an LG v30 with this App, with tethering via USB this practically will make us able to use the phone as a external dac (and a REALLY good one).
I guess the only way to get this it’s having the option to select 16Bit or 24 Bit from the Android App. Because 44.1 (16bits) gets up-sampled by Android to 48hz and it messes the audio quality
