Hi, I’m wondering if this app downsamples 24-bit audio streams. I’m planning to use the app on a LG V20 running Android 9, so I’m trying to get the most out of the Quad DAC.
Hey @Hadi_9,
The app supports only 16-bit for now.
Thanks for replying!
Another question, if you don’t mind: If I happen to play 24 bit audio on PC while using “uncompressed mode” in your app, does the audio get downsampled, or does it simply not output audio?
You would hear it, the audio is converted.
