Auto reconnect
Please add this feature
Need this feature otherwise no point in this app.
I have one single gripe Audio Relay. There is no auto connect. Every morning when I start up my workstation, and gaming PCs, I have to open up Audio Relay and manually connect to my gaming PC. This seems super minor, but it would be a huge quality of life feature to have a setting to auto-connect the player to your last used server (or a specific one), if you are willing to consider this as a future feature.
Hey devs,
I need the adroid app to automatically trying to reconnect on loss.
For context: My soundsystem connects over AudioRelay to my HTPC, but i turn my HTPC off automatically (Sleep Timers etc.)
So every evening i have to reconnect the app manually to have tone.
I would like to have a reconnect feature in App. Is that possible?
Hi devs,
The application genuinely works great, it’s easy to use and the connection is reliable while also being fast. But I think this is really an essential feature for an app such as this. Is their a certain technical or design reason why it wasn’t implemented yet?
Love the application. Is there any estimated time frame on when a auto-reconnect or auto-connect feature would be implemented?
Six years and nothing? Holy crap even my company is better than this.
Guys seriously, I love the product, but it is annoying. Please spend half a day coding it. Fire off the existing module that gets fired when you click the button if the check box is checked. 1 setting, 1 checkbox, and a couple lines of code. Easy
Please!
